Xm 2.0i 8v XU timing belt cross reference... :-(
andmcit
x 30
Unread post by andmcit »
Hohum!
My timing tensioner has run it's bearing out and collapsed allowing the belt to unravel whilst
I was driving. In hindight I realise now a noise that had just developed was the tensioner/idler
rather than the hydraulic pump I thought it was...
Anyhow, damage limitation exercise coming into effect!! First off - does anyone know if the
valves are clear of the piston in such a scenario or is there overlap?
Next off, as GSF dont directly list any Xm tensioner, does anyone know if it's the same as
the Xantia 2.0i 8v as there is a listing?
Andrew
x 8237
Oh dear Andrew :cry:
Interference as far as I know but damage can be limited by the fact that the valves are perpendicular to the pistons and thus a bump up tends to push then straight up rather than bending them. The camshaft breaks instead :wink: Chances are, you have got away with it.
Yes,the belt and tensioner should be identical to the Xantia 2.0L 8V. All 2.0L 8V engines use the same.
I can look in pr.net for a conclusive answer of you wish Andrew. What is the engine code?
andmcit
x 30
I'M ON A ROLL AT THE MOMENT! CALAMITIES JUST FIND ME THAT
BIT EASIER... :x :shock:
I'm pretty certain from checking the part numbers on Eurocar Parts
website the two engines do cross reference OK! TBH, I'm not 100%
sure where I'd find the engine code although it should be a XU10J2
engine. The timing belt'll likely need replacement although it is recent
and the tensioner did 'seem' to be OK at the time I checked it out on
a clutch change job.
Andrew
x 8237
Yes, it'll be the XU10J2 Andrew and according to pr.net, all the XU10 8V family use exactly the same tensioner and belt.
