Knocking Xantia 2.1TD Exclusive
HST
The car is making knocking noises, I think from the front left. It is speed related, maybe 1-2 knocks per second at just over walking pace, increasing somewhat with speed. It doesn't seem related to bumps in the road & continues when declutched. Any ideas??
DickieG
- Monaco's youngest playboy
- x 38
HST
DickieG
- x 38
OK I should have asked does the noise vary? The point that the noise does vary indicates that the driveshaft is more than likely the cause.HST wrote:Not noticeably: if anything it can decrease.DickieG wrote:From your description, it sounds like a worn driveshaft. Does the noise increase when turning?
What you could do is to jack the front of the car up (both wheels properly supported on axle stands) and get an assistant to 'drive' the car whilst you observe the driveshaft, it should run 'true' but if faulty, may 'wobble', and listen for the source of the noise etc.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
AndersDK
HST
Ok, the rain has stopped & I've had a chance to look at the car. The answer has me a little confused as it looks like it was down to loose wheel bolts. The reason I'm confused is that the car has sat for about a week & was OK when I parked, but was making the noise as soon as I drove off. I'm used to local ne'er do wells messing with my bike, but it'll be a real pain if I have to keep checking my wheel bolts..
There was no vibration driving or odd sensations apart from the noise.
DickieG
- x 38
- x 8137
That is odd
The only explanation I can offer is that of expansion/contraction. Could the wheelnuts last have been tightened when the weather was hot and the wheels warm? Perhaps it is now colder where you are, especially if it has been raining and the contraction of the alloy wheel was just enough to loosen the nuts, along with a bit of roadgoing vibration over a period of time. Lorries and trailers (caravans even) suffer this and hence why all lorry and bus wheels have those little yellow pointers on their nuts to see at a glance if they have loosened.
Else, it's your local neighbourhood vandals
Speaking of rain, where are you? It has been dry for weeks upon weeks down around here, so bad we have cracks in the lawn...
deian
HST
