Xsara rear passenger door.
simonelsey
Unread post by simonelsey »
Hi , DOe anyone now anythnig about the doors on a 2000 xsara hdi.
The door will not open , from inside or out . Seems handle/latch not working , Can hear central locking opening/moving .
Is it a difficult problem seeing as cannot open the door .
Any advice welcomed.
2.0 hdi xsara estate been a pain but starting to look like a good buy
x 8063
This used to be a very common problem on Pug 205s and the like. Usually caused by a sticky lock mechanism. You'll most likely find the door release is stuck in the open position and a touch of WD40 around the latch mechanism and it's linkage rods will fix it. The problem is, getting it there :evil:
The only way I ever found was to carefully remove the door card from within. Not an easy job at all but possible. You may have to remove seats :( to gain sufficient access.
Good luck!
simonelsey
Had a look today , cannot get arm rests off as stupid star screws . Anyone now what size and what the star heads are called.
I think the contorol arms have poped off as when I locked up the other day I heard a clang as the motor operated .
I feel pretty confident if I can get the right tool. :oops:
jeremy
Unread post by jeremy »
the star shaped socket headed screws are Torx headed. Your best bet is to buy a collection of bits like those illustrated in the link which will mean you can deal with most that you will find in your Xsara.
http://www.machinemart.co.uk/shop/produ ... and/clarke
jeremy
