C5 2.0 HDi 110 Estate, tick over adjustment, wheel wobble.
210national
Can anyone tell me how to adjust the tick over?
Also any sugestions on how to cure wheel wobble?
Steve
Steve
- x 1238
- x 1431
210national
C5 HDi Wheel wobble
This happened at 65-75MPH with my old tyres and is still the same with new Balanced Goodyears.
- x 1238
210national
C5 wheel wobble
Thanks for all the posts.
I have just had new front Tyres, as the rears are ok.
- x 1238
210national
- x 1238
210national
Hi Peter,
Now you mention it it does sometime disapear after turning corners also on occasions its not present.
It manifests itself as oscilations of about an inch (not bean converted to decimal yet), on the stearing wheel and it doesent seem to be evident on the body.
I have read on other forums that this is a problem with the C5, but i cant get to the bottom of it.
regards
regards
SandyD
- x 1238
Hi 210national
That would indicate that there are two wheels out of balance, when you corner the relative position of the wheels to each other changes, due to the fact that the 'inner' wheel turns more slowly. As they go in and out of 'phase' the vibrations either add to or cancel each other. Sandy's suggestion might be worth a try.
210national
C5 Wheel wobble
Hi,
Thanks for all your replys, i have noticed that the locking nuts are a lot smaller ( and therefore lighter) than the rest of the wheel nuts, could this be the problem? i will try replacing these locking nuts with standard wheel nuts.
Will post results.
Thanks again.
Steve
Will post results.
Thanks again.
Steve
SandyD
I would keep your locking wheel bolts fitted for security. And yes the locking bolts are lighter than the normal bolts that is why you fit them to the heaviest spot on the wheel in line with the valve stem. As you know the wheels are balanced off the car and then fitted to the car but I think you’ll find the bolts are not all in the same place on the wheel, so all you have to do is swap them round and give them a try.
Sandy
Sandy
curly
wheel wobble
Hi I had the same problem with my C5 2.2 HDI, I replaced the lock nuts and had all the wheels balanced .Don't have any problem now. Why do you want your tick over increased?
Curly
Curly
