Gear Links ?
Twiss
Gear Links ?
Unread post by Twiss »
Hello People
Could someone tell me where I could buy a set of Gear linkages from ? Other then Citroen them selfs.
I tried GSF but I dont think they do them any more.
Thanks Vaughn
x 1432
Dealer only I think. They're not that expensive - the two bottom links (P/No 2454 E6) are £12.57 each, and the longer top one (P/No 245275) is £19.75. It's usually only the top one that needs replacing - it breaks apart at the gearbox joint.
weety
Unread post by weety »
can be worth replacing all of them...gives you a nice tight feeling gearstick....just like a new car
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
jeremy
Unread post by jeremy »
Its worth lubricating the bits you don't dismantle - like the gear lever bearings - it makes a surprising difference. I used spray grease on the gear lever - which is easy to apply!
jeremy
Twiss
thanks For your help. I'll get on and order the parts and hopefully when the weather clears for abit , do the job.
thanks Vaughn
davek-uk
Unread post by davek-uk »
Jeremy, what spray grease do you use? I've seen thick, sprayed grease on car linkages before but have never seen spray grease on the shelf that seemed similar - most of it appears to be thin stuff. Do you have any recommendations?
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
jeremy
The stuff I use is quite thin with a solvent that evaporates rapidly leaving a moderate film behind. The first can I bought was Comma from the motor cycle section of Halfords - and the present one came from my friendly accessory shop and may be Morris's
I find it penetrates quite well and of course doesn't run away and evaporate like engine oil.
jeremy
davek-uk
Thanks Jeremy, I'll have to buy some and try it. I note GSF have gone over to Morris in a big way! This kind of puts me off as I had a Morris Ital once, and it wasn't what I'd call technically advanced - more technically challenged...
jeremy
Ah yes but Morris Oil run a Sentinel steam lorry so all must be good!
http://www.channel4.com/science/microsi ... index.html
And - yes they stock a specially developed oil for its crankcase!
http://www.morrislubricants.co.uk/
I've used their products (not exclusively) for years and always found them fine - but to be fair when I've used anything else it hasn't lead to instant siezure.
jeremy
Twiss
Well Ive done the job and what a difference its made. only thing is now Ive sorted the gear links ( new ones ) out plus other things, I can hear a clonking noise when I change gear but it only happens when I'm drving the car it doent happen when the engine is off or when engine is running and I'm just putting her in gear. The clonking doesnt always happen every time I change gear but mostly happens in 3rd and 4th.
Sound seems to be coming from the gear box side of the engine.
Any ideas what it could be ?
or is it because the gearlinks are new ?
Thanks Vaughn
Peugeot 206 1.4 SW, huge amounts of space for a little estate, feels responsive in the corners.
Twiss
anybody got any ideas at all??? :)
