Hi all,
I'm having a look at a 2001 reg Xsara 1.6 VTR Coupe tomorrow, it has 82,000 miles on the clock. Just had 4 new tyres & a timing belt.
Is there anything specific I should be looking out for? Any common faults.
Thanks.
Xsara VTR Coupe?
Stuart McB
Kitch
Head gasket. I've seen quite a few TU's fail early if they don't have the right coolant mix. Not really a problem as they're very easy to fix and I've never seen a petrol head get warped.
Stepper motor is a common thing, as are the two coolant sensors on the thermostat housing on the side of the head. Ones blue and ones green IIRC.
And noisy clutch thrust bearings.
1991 Citroen BX 16valve
1998 Citroen Xsara 1.9TD SX
1993 Peugeot 106 XSi
1995 TVR Chimaera 400
boroboy
Thanks for the advice guys.
Had a look at that mk2 vtr a couple of days ago, 2001 with 85,000 on the clock, wanted £2000. Initially I thought it was a good price, after driving it I gave it a miss. Air bag warning light permanently on, very stiff clutch, front disc judder under braking & body work not too good. Obviously had a tired life. Not as advertised, 4 worn tyres & not in excellent cond & guy forgot to tell me about the airbag warning light.
