Orga number for the Xantia antisink start?
ekaftan
x 8
Unread post by ekaftan »
Where can I find from which Orga a Xantia would come with antisink?
Thanks.
slim123
Unread post by slim123 »
Cant remember the RP no that anti sink came in on, but it was about half way through the L reg cars.
Easiest way to tell is to look at the hydraulic pump, early cars without the anti sink were fitted with the 6 cylinder (2 pipe) pump and the anti sink models were fitted with the 6 + 2 cylinder (3 pipe) pump.
Also the non anti sink has a flow distributor valve, whilst the anti sink cars dont have one.
Regards
Slim.
ekaftan
x 8
slim123 wrote:Cant remember the RP no that anti sink came in on, but it was about half way through the L reg cars.
Regards
Slim.
Midway through L means, late 94 mode year, right? I am buying one made
in July 94, so it should have antisink. I will check the pump monday. It looks the same as the one in my 96 and not like the one in my BX...
x 695
Unread post by Mandrake »
A quote from one of the Citroen manual suppliments I have:
"Since december 1993, all the XANTIA vehicles with power assisted steering have been equipped, in production, with the "SC/MAC" (Citroen system of maintenance of a constant ground clearance).
NOTE: Japan has been fitted with the "SC/MAC" in july 1994."
Checking for one or two steel output pipes from the pump is still the only sure-fire way to know of course...(who knows how long cars sit in stock before selling)
Regards,
ekaftan
x 8
Mandrake wrote:A quote from one of the Citroen manual suppliments I have:
ok. that confirms the car has antisink. It has two steel pipes. It also confirms its broken :) as the car goes almost to the floor as soon as I start the engine, then comes back up...
f00lzz
Unread post by f00lzz »
Regards,
Very true.. my TD came of the production line in April 98 and was first registered in December 99
But regardless... I think the 'non' antisink cars seem more 'Citroen'....
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
nick
Unread post by nick »
As a rough guide, the earlier cars with the badge on the bonnet & a two spoke steering wheel didn't have antisink, whereas those with the later badge on grille & four spoke wheel with airbag did have antisink.
There was no exact changeover point in terms of registration date - I've seen a few of the earlier type on M plates, and the later type on L
x 695
nick wrote:As a rough guide, the earlier cars with the badge on the bonnet & a two spoke steering wheel didn't have antisink, whereas those with the later badge on grille & four spoke wheel with airbag did have antisink.
I wouldn't go by that...
The chevrons moved from the bonnet to the grill during 1995, well after the transition to anti-sink. My Dad's mid-1994 model has chevrons on the bonnet but does have anti-sink... and whether the car has an air bag has nothing at all to do with it... (and is very region/market dependant)
Regards,
nick
Mandrake wrote: I wouldn't go by that...
Regards,
In the UK the "official" date for the introduction of the facelifted model, drivers airbag and antisink was July 1994 - doubtless there are exceptions, and it will also be different in other regions as you say.
BonceChops
Unread post by BonceChops »
Is it not easier to look for the rear middle sphere underneath?
Now Citrtoenless
mezuk04
Unread post by mezuk04 »
BonceChops wrote:Is it not easier to look for the rear middle sphere underneath?
I was also just going to suggest that myself :)
Volkswagen Golf 59' 1.6TD S :(
ekaftan
x 8
Not that easy when looking for a car to buy and you are wearing business clothes :)
