Got a problem starting the BX - starter motor turns but the engine will not fire up. Glowplugs and filter have been replaced, I primed the filter whilst trying to start this morning. Engine turns over, will not start and the sound whilst the starter was turning over was different to the normal sound when it would start.
Any idea what the cause is?
Many thanks
BX Diesel starting problems
beemernut
BX 19 Meteor Diesel 1990
BX 19 TRS 1987
BX 17TZD Estate 1992
XM 2.0SI Mark 1 1990
In the words of OGRI "Stuff Everything - I've always got my bike" (or should that be Bike & Citroens?)
BX 19 TRS 1987
AndersDK
Do some simple checks :
Check there is voltage present on your shining new glow plugs. They need power you know
Sit down by your dining table - with a pen and paper. Then think-think-think-think-think-think : what did you dismantle to change those glowplugs ? Write it down - every single word valid for the process.
Then check all bits related.
Its unbelieveable how many new problems we introduce when we solve one problem as diy'ers
Anders (DK) - '90 BX16Image
beemernut
BX Starting Problems
When I changed the glowplugs, there was a slight improvement in starting, but starting the engine required the engine to be cranked for a short period of time. This has worked, but occasionally the starter motor would not turn at all when the engine was hot.
Could it be a problem with the glowplug black box (by the battery)?
My wife said that there was a noise upon starting last night before the engine stalled and wouldn't restart - this is when the engine would turn over but not start
BX 19 TRS 1987
BX 19 TRS 1987
Stinkwheel
Oh dear, maybe.My wife said that there was a noise upon starting last night before the engine stalled and wouldn't restart - this is when the engine would turn over but not start
You now say the thing doesnt sound the same when turning over? Has the cam belt snapped?
"Rust Never Sleeps" said Neil Young. Did he own old citroens?
1998 Xantia TD exclusive auto estate +3 x BX's +77' ami 8 break + 73' dyane 6 + '83 2CV6 + 94' XM 2.1 sx auto + 89' XM2.0i
+ '85' GSA + '97 XM 2.0 16v + '81 Visa super E
- x 1240
- x 1485
beemernut
BX Diesel Starting Problems
The car (untilyesterday) has been running fine apart from the odd time when the starter had seized temporarily due to heat.
The change in noise is as if the starter is turning slightly slower and you do not get the feedback of the engine just as it is about to try to catch. That is why I thought the car had an air block in the fuel line - it just turned over and would not start catching
From memory there has not been any noises that I would expect from the cam belt going (the crash of pistons against valves). The engine seems to be turning over in the normal fashion.
BX 19 TRS 1987
BX 19 TRS 1987
bxbodger
So the engine is turning over normally- Have you checked the cut-off solenoid on the pump? i don't know what your pump is, but on a Bosch one it's easily visible on top at the opposite end to the sprocket, with a (usually) brown wire going to it. I'm not sure where it is on a Lucas pump, however.
It's what stops your engine running when you turn it off and if this isn't working properly, fuel won't get pumped through and it won't start. it may also be intermittent.......
First check-hot wire it directly from the battery with a length of wire and see if that makes a difference to starting. If it does, then you've probably got a fault in the 'ignition' (for want of a better word) circuit.
They also easily come out so you can do a physical eyeball check that they are working by connecting to the battery and earthing.
Easily and cheaply available if the thing is busted!!
- x 1240
wrinklet1
- x 94
