Problem with Fan Blower ?
pikecrazy
Unread post by pikecrazy »
A strange one this...........
The blower for the windscreen etc decided to come on its own , full power never touched it.
Anyway i cannot turn it off other than pulling the fuse .
Any ideas what i can do to fix this problem :?:
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim :-)
f00lzz
Unread post by f00lzz »
Yes... common 'characteristic'. It will be the heater blower resistors which can be replaced with a little bit of drilling and soldering (easy stuff) The motor is located in the passenger footwell under the glovebox just a few screws and it's out..... LOTS and LOTS of posts on getting the right resistors and pics of how to do it on here, just use the search facility... if you get stuck I have done it several times and even have spare resistors if you need help!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
x 1484
But if it's got climate control it will either be a fault with the transitors in the fan controller, or possibly the internal temperature sensor in the dash.
f00lzz
I believe that a year 2000 HDi will be fitted with Climate control and my money is on the Blower Resistors
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
x 1240
Unread post by Peter.N. »
They are actually 'transistors' and they usually go intermittently open circuit, so it works sometimes. It sounds as though yours have gone short circuit, which would result in continious flat out operation. Type No at the bottom of my signature.
pikecrazy
Thanks for the help :D
This may take some time as i am not electrically minded :lol:
f00lzz
Here to help!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
mezuk04
Unread post by mezuk04 »
I'm not electrically minded also, but I am incredibly handsome so that seems to get me by :D
Volkswagen Golf 59' 1.6TD S :(
f00lzz
Is that your pic in the avatar monkey boy lol
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
