it sucks
x 94
it sucks
Unread post by citronut »
what could be the cause of the intercooler duckting sucking its self in,on a xantia 19 TD
regards malcolm
mpr1956
Unread post by mpr1956 »
Hi Malcolm, I have heard that this can be caused by the fibrous tubular ducting under the air filter box becoming perished and collapsing.. causing a vacuum in the intake. best wishes, martin
I won't do that again
x 1240
Unread post by Peter.N. »
The intercooler ducting should be under pressure, otherwise there would be no turbo boost, is the turbo boost present? The only way the hose would collapse, due to vacuum, would be if the turbo wasn't working. Are you sure its an intercooler hose?
Dave Burns
Unread post by Dave Burns »
What martin said, or blocked air filter.
Air can still get through the compressor in quantity, running or not.
Dave
x 94
this is not my car but one that is a customer of the garage i use for mine and my customers MOTs,all of the duckting and the air filter has been checked and replaced where nassacery,it still dose the same but not all the time
regards malcolm
