not french car realted .. welding question
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
guys thanks :)
have brought a pack of 1mm tips.. (for .9 fluxed) on M5 thread... will check mine tonight to see thread size (the tips were opnly cheap)
I have done some mig a few years ago, its coming back slowly..
The first job I need it for is a tiny non structural weld (see top) so I will work something out for tonight tomorrow.. the main concern now looks to be bad lniing and getting 2.5 meters or so of new stuff, that will take 0.9..
Will check rollers out etc as well :)
ps anyone one a portable butch single phase Stick welder, welds up to 12mm! ;)
with some rods,,,,
J
406 V6
Unread post by 406 V6 »
Regarding the roller, i'm using successfuly the 0,8mm side with 0,9mm fluxed wire ;) and due to a stupid mistake (welding to close to the tip and sticking the wire to the brass) i had to drill the tip out to 1,5mm. But it still does the job :P
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres :D
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
jgra1
(Donor 2021)
x 36
that was my plan tonight ;) to 'get me out of a hole' so to speak ;) was to re-drill my tip for this one job..
jgra1
(Donor 2021)
x 36
it works!!
Took roller out and reveresed it.
Took blue inner lining out of main cable, tried a test peice of .9mm in both ends, no problems
Tight but good fit in the Tip.
the only real problem was the spool holder was set up for large reels, so I removed that and added a long 10mm bolt and used that as holder.
The original job is done, it wasnt pretty but fine for what i needed. :)
the welder was 'stabbing' at the work a bit, i tried chaging the speed once, but otherwise all was good.. now what I will do is practice, there's lots of info on the web ..
happy John
x 1480
"the welder was 'stabbing' at the work a bit"
Wire speed too high (it feeds in faster than it can be melted).
jgra1
(Donor 2021)
x 36
Thanks Rich, did turn it down to 2 speed.. but maybe the power was wrong, and the work wasn''t that clean so may not have been a good arc..
I will definatley try on some scraps...
x 94
Unread post by citronut »
you get a far neater weld with a gased mig welder,i tried a gasless mig once that was enough never again,i use a large 190amp machine with it set to 3 on the power range out of 6,and thats welding dershes(2CVs,one thing to remember is you have to get full penatration,HE HE HE
regards malcolm
jgra1
(Donor 2021)
x 36
thanks Mal will bear in mind..
another question.. my welding mask lets enough light in so I can see (if i look quite hard) without current running.. is this ok? - I brought second hand..
the red glow of new weld looks same brightness as i remember, but suprised i can see anything really? - when not welding...
406 V6
I don't know of mask wearing out with time... Check the number it has (usually) printed on the glass. For low current MIG (120A +/-) a #8 should be used for a good view of the welding job and still offer protection.
I was using #11 glass and i couldn't see much of wath i was doing. Only good for arc welding, really.
I've bought a couple of weeks ago an electronic mask for 15 euro-bucks. One of the best buys i ever made! Just put the mask on and start welding. In the instant you strike an arc, it goes fully black, and mine, being #3 when not welding and #11 welding allows a good view of the weld (must be the fumes depositing on the external glass that don't make it that dark :) )
Francisco
jgra1
(Donor 2021)
x 36
thanks 406 ;)
15 Euros?!
I am sure they are around 100 of those here? seems a good deal!
John
406 V6
Yeah, 15 euro! The other hardware store down the street had one for 100 quid! I even asked the price twice when i saw this one! I was stunned :shock: I believe i'll buy few of those and sell them for 25€.
Francisco
jgra1
(Donor 2021)
x 36
can i be first on your list of customers?
where in Portugal are you?
406 V6
I live on the outskirts of the capital, Lisbon. I'll check the prices tomorrow morning as a friend asked me for one. If the price is the same, i'll buy some 10!
Gee, i wonder how much for mailing it to the UK? :D
Francisco
weety
Unread post by weety »
jgra1 wrote:thanks Mal will bear in mind..
i use a couple of these high brightness lamps you are meant to use outside, you shine those at what you are trying to weld and you can usually see it really clearly......careful though they get very very hot
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
jgra1
(Donor 2021)
x 36
Lisbon eh? ;)
just so happens my collegue goes home there often ;)
not usre he will get a scary mask thru as hang luggage tho :twisted:
