Xantia TD Ribbed Belt Tensioner Bolt Help!
PicassoPigeon
Unread post by PicassoPigeon »
Its 19mm that holds on this auto tensioner thing but i cant get it off with my spanner so i thought i would try a socket and breaker bar but the normal 19mm socket on the breaker bar will not fit between the the side of the car. Is there a short socket that i can buy or a socket that you can put in place of the knuckle on the breaker bar?
How can i get this thing off?
Going nuts here!! :evil:
gav425
2002 Citroen Xsara Picasso 2.0HDi
125,000 miles
x 1432
Any chance you can hit the spanner with a hammer? Can you get a pipe on the spanner? Might you be able to remove the engine mount and jack the engine up and get the socket on? Would you get it on with a wobble extension or universal? Can you get some heat on the bolt with a blowlamp or similar to help free it?
It's not LH thread by any chance :twisted:
PicassoPigeon
Have now undone the bolt but it hits the chassis so i cant remove it.
Is it possible to remove the alternator mounting, is that what this tensioner is fixed too. i could then remove it off the car. :evil:
gav425
125,000 miles
KennyW
x 163
Unread post by KennyW »
Hi Gav425,
Can I ask why you are taking bolt off :?:
As I only did it when replacing tensioner as the bearing had shot the bolt causing the ribbed belt to shred.
Cheers
Kenny W.
C3 1.4 petrol (SWMBO)
PicassoPigeon
Replacing the tensioner as it is the cause of my belt shredding, it has kicked out of line and so pulling the belt away so that it jumps off the HP pump.
By leaving it like this for sometime i have then seized my alternator.
gav425
125,000 miles
Dave Burns
Unread post by Dave Burns »
I think the bracket will have to come off, what a ball ache.
If you have got a belt from GSF then it might not fit, the length for my 1.9TD aircon model is 1725, GSF only list them to 1690 and they wont go on anyhow.
Dave
PicassoPigeon
I have got a belt from GSF it 1733 the one that came off was 1735, i hope i will be ok.
Best get on with getting this bracket off. cheers for your help and yes it is a ball ache. :evil:
gav425
125,000 miles
KennyW
x 163
Hi Gav,
I found when changing my tensioner i had to move the power steering pump ,out of the way .
Once I did that and a fiddly bolt holding the tension spring the bracket and bolt were fairly easy to remove.
Bit of a B****r to put the tensioner spring bolt back.
Good Luck
Kenny W.
PicassoPigeon
Just to say thanks to everyone, I have now completed my task. I removed the whole alternator bracket and this made it very easy to replace the tensioner and spring out of the engine bay. Its a bummer of a job but its done now. Thanks once again.
gav425
125,000 miles
