Its 19mm that holds on this auto tensioner thing but i cant get it off with my spanner so i thought i would try a socket and breaker bar but the normal 19mm socket on the breaker bar will not fit between the the side of the car. Is there a short socket that i can buy or a socket that you can put in place of the knuckle on the breaker bar?
How can i get this thing off?
Going nuts here!!
gav425
Xantia TD Ribbed Belt Tensioner Bolt Help!
- PicassoPigeon
2002 Citroen Xsara Picasso 2.0HDi
125,000 miles
125,000 miles
'13 3008 1.6 HDi GripControl - x 996
Any chance you can hit the spanner with a hammer? Can you get a pipe on the spanner? Might you be able to remove the engine mount and jack the engine up and get the socket on? Would you get it on with a wobble extension or universal? Can you get some heat on the bolt with a blowlamp or similar to help free it?
It's not LH thread by any chance
- PicassoPigeon
- KennyW
- My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate - x 132
Hi Gav425,
Can I ask why you are taking bolt off
As I only did it when replacing tensioner as the bearing had shot the bolt causing the ribbed belt to shred.
Cheers
Kenny W.
Cheers
Kenny W.
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
- PicassoPigeon
- PicassoPigeon
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Hi Gav,
I found when changing my tensioner i had to move the power steering pump ,out of the way .
Once I did that and a fiddly bolt holding the tension spring the bracket and bolt were fairly easy to remove.
Bit of a B****r to put the tensioner spring bolt back.
Good Luck
Kenny W.
Good Luck
Kenny W.
- PicassoPigeon
Just to say thanks to everyone, I have now completed my task. I removed the whole alternator bracket and this made it very easy to replace the tensioner and spring out of the engine bay. Its a bummer of a job but its done now. Thanks once again.
gav425
gav425
125,000 miles
125,000 miles
