I had a problem with my Xantia brakes involving stickiness and uneveness, akin to a warped disc. I also began to experience an alarming groaning noise on gentle right-hand bends and an even more alarming vibration under hard braking - suggesting a disc might be cracked! The discs aren't very old so I checked (for the umpteenth time) and confirmed there was no warping, no apparent cracking and no corrosion. Decided to take a closer look at all components and noted that one pad was more worn than the others. Following this train of thought, I cleaned the pin at the base of the caliper and also cleaned out the corrosion behind the small clip that locates the pin. A bit of Copperease and Voila! It seems the corrosion products behind the clip create pressure on the pin, preventing the caliper from centralising in tune with movement of the hub/disc.
A cheap fix and something I'll include in the next service.
Groaning, uneven brakes - it might be...?
- My Cars: C5 2.2 VTR + Nav 173
Mazda 6 2.2 Sports Nav Estate
Jaguar 3.8 MkII 1961
Ex 2007 C5 2.2 Estate
Ex 2003 C5 2.2 Estate
Ex Xantia 2.1 TD Exclusive
Ex BX 1.7 DTR
Ex BX 1.9 TRS - x 1
John
'59 C5 2.2 173 VTX+ saloon, Jaguar 3.8 MkII 1961
RIP - '07 C5 2.2 173 VTX+ Estate
