I have therefore placed the wire end into its slot and held it down with some strong tape, so now the wire moves with the control knob at the front, and also the circular devise to which it is connected to also rotates.
When moving the outside control from side to side i can hear a noise of flaps moving from underneath the glovebox.
So can i assume that the recycle is now working, bearing in mind the wire is in its slot and does not come out, the circular thing moves and also the noise under the glovebox when I operate the control.
