Hi, it started as a work-dont't-work but after a few days turned into no operation for the drivers window switch (the one with the 4 buttons)
It did on accasion when i pressed up-full go up in increments rather than all the way. I noticed there is a bulb in this one (can't remember if it worked before) that is not illuminated.
Took out the switch giggled and contact spayed the two ends but no luck.
The haynes manual states both front side windows share the same fuse i discarded this problem as the passangers window is working fine.
Where would i be looking for the prob next?
What are the easiest checkpoints short of declaring the motor is gone.
Tnx.
XM driver's window anoyance
andmcit
- x 30
The control relay lurking behind the driver's door trim area is the most likely suspect, followed by the actual one touch switch on the driver's door - then you're looking at possibly flexed wires in the door jam loom - [it does still happen on the Xm].
Doesn't sound as though you've got the duff plastic guide on the glass syndrome just yet if it's totally dead...
Andrew
Andrew
rowanmoor
I recently had a very similar problem. It would go up part way and stop. It turned out to the the switch - it had started disintegrating inside. The reason it would go part way was that you would press the 'auto-up' button, and then another button would give a 'blip' afterwards making the controler stop the window. I too had noticed the bulbs stop working in it.
Mine was fixed with a new switch (about £30 from Citroen!).
You could probably try a multimeter on the switch to get an idea if it is doing odd things or not (I expect one of the other buttons is jamming on if it is the switch). Do the other buttons work at all?
Cheers,
Rowan.
Rowan.
davetd
andmcit
- x 30
Great idea!
Mind, when did you last see an Xm ANYWHERE, let alone in a breakers!?
The last one's around are being pushed out for peanuts on ebay and mostly these appear to be being run into the ground as bangers - and the nice one's are being scrapped for their turbo engine to power a boy racer's Peugeot 106 that likely isn't insured etc...
...when they're gone, they're gone!!
Andrew
Andrew
- x 1238
I saw ten in France this week! and dozens of BXs.
Back to the plot. The switch is the most likely problem and they sometimes dont respond to an application of WD 40. You can dismantle them and clean the contacts but its a fiddly job and you are likely to loose something. There are a number of XMs being broken on ebay, I would have thought that would have been your easiest course.
Robin
I agree that is most likely the switch but there are two versions. They look very similar but they do not function the same and use differing registers on the connectors to prevent your connecting the wrong switch.
Good luck with the hunting. Robin.
Citroens are dedicated to those who take a big bite - and just keep on chewing!
nino1
- x 1238
AndersDK
Might be worth visiting the XM specialists :
http://club-xm.com/forum2/index.php?act=idx
Norrie (noz) and his gang certainly knows the ins & outs of their XM's - and may provide a prompt answer - even a schematic
Anders (DK) - '90 BX16Image
nino1
nino1
rowanmoor
If you know of a scrap yard anywhere in our part of the country with an XM then let me know.davetd wrote:You'd be better going to a scrap yard and buying a handful of switches to try for next to nothing rather than buying new
Last time I tried to find anything I heard a rumour of one on the coast somewhere - but it is not worth me driving 30 miles for something like a switch that has a good chance of being fairly dead too.
The online scrap searches sometimes find XM parts if you are lucky - but courier can be costly if it can only be found in Scotland.
Cheers,
Rowan.
Rowan.
wrinklet1
