Well now ... the missus's Xsara went in for MOT today and duly failed - nearside CV boot insecurely mounted, ie not where it should be. Now we know what that 'tinkling' noise was which eventually disappeared. Must've been the original clip. Bl**dy hell i said, have i got to come back? Yup was the answer. Clean it, grease it and stiick a cable tie on and bring it back he said. Now then ... clean it, no problem. Grease it? I checked and theres not much grease left inside so how much is enough? Presume CV specific grease? And the age old problem of cable ties. These cars seem to rip off a cable tie as much as look at one so my question is what size is optimal width? I know its a daft question but if i stick a small rubber band of a tie on will it pass or do i need a more meaty 8mm or even 12mm? He failed both sides even though drivesr side looks as dry as a bone to me. Must have caught him having an off day as he didn't want to know when i asked if he could fix it today. I'm assuming it would have taken about 15mins to do? Probelme is i've got to get it back in within two days for a free retest and its the Arsenal game tomorrow night so i'm only going to get an hour at this and want it to be done right. Any hints or tips on what the tester might crib at next? Cheers .
Update .. i've just checked and i've only got slim ties that'll fit around the circumference. Any problem if i use two of these. Or is this just a bodge and will be failed for what it is?
CV boot question
AndersDK
Mike -
Cable ties are about the cheapest spare parts in the world - honestly
Find, gauge or calculate the correct width & lenght of the cable ties needed - then purchase a few !
My gueestimate you need some 8mmx60mm cable ties.
The grease to use is any standard grease for joints, ballbearings etc - known as Molykote (MoSO2 - molybdene disulfide) - the wellknown black grease. Can be purchased in tubes where you get standard parts for cars.
Anders (DK) - '90 BX16Image
JohnD
- x 72
dnsey
- x 19
alan s
- RIP 2010
- x 6
Some service manuals advise against using zip ties to hold boots on and insist they need the metal ones due to them getting a bit soft and pliable when they get hot.
I have had them supplied with metal straps (aluminium) but not the Ligarex style. By the same token, I've also seen zip ties used as a permanent measure to hold rdiator fans in place so it obviously depends on whether your man has a bit of a fettish against them. I doubt that one about 6 or 8mm wide would do much stretching once in place but suggest a phone call and simply ask him if he will accept them.
Alan S
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
smashymike
Thanks all ... from whats been said i think this guy must've just been having a bad day. I've stripped down the boot, cleaned it up and am going to fit a 12mm cable tie. Should just about hold everything in place and looks juts about the correct width for the boot lip. Had a quick squint inside and theres not a lot of grease. Just a smidge on the joint itself. Should i fill the boot with black grease or just put about a couple of golf ball sized chunks in there. Doubt it'll get opened for some time ... it's going in again tomorrow afternoon. Keep you posted.
bxbodger
Cable ties will be fine- all the test requires is that the boots aren't split, and that they are secure. How you secure them is up to you.
The amount of grease isn't critical, as long as there's some there. just push some into the joint before putting the boot back on. You usually get a fat sachet of it about 2 inches long with a new joint, so its probably about a capucino cups'worth.
Don't completely fill the boot with it- it'll just make a horrible sticky mess going back on as it's displaced by the joint.
- x 94
smashymike
Aaarrrrggghhh .... didn't quite make it to the MOT because i can't get the boot secured properly!! Cable tied it, looked aok but when i put full lock on to test, boingggg, off it comes. Did this three times before i gave up on it. There's no play in the boot to allow it to flex when on full lock. Checked the drivers side and it looks like the inner clip on that side has a bit more 'loose' in it so it slides along the shaft when on full lock allowing the hub end a bit more play so i tried to move the nearside a bit. No go, its solid. So, any ideas. I'm thinking i'll have to break the clip on the inner shaft end and replace it with a cable tie to see if all will hold together but i've not got much hope. Looks like i need a new 'wire' clip like the original. Where from though?
smashymike
AndersDK
JohnD
- x 72
mezuk04
dnsey
- x 19
bxbodger
Well I've had one on for 80000 miles now with no problem....you do need to use decently thick ones though, pull them up tight, and like Dnsey says it has to be clean.99% of the time when cable ties have been used they do not hold the C/V boot tight enough,so the greas leeks and that sould then fail the MOT
