Tomorrow i shall be attempting to cure my wonderfull xantia's
Recently the front near side sphere failed causing a lack of suspension travel on that corner. I have since replaced both front spheres and all is well (almost)
When changing the spheres over i lost about 2l of lhm fluid due to it generally going everywhere (even with system de-pressurised) as the dead sphere and entirely filled lhm.
I initially only had 1l of lhm spare and i put that in and ran the car, after hearing it sucking in air i went and got another few litres of the stuff and it took an entire 1l bottle for it to read just under the max line.
Now here comes the problems, there is bound to be air in the system somewhere i just need to get it out!
I have tried the citreobatics thing which has helped to an extent.
When i first drove the car again the front end seemed to excesively wallow over bumps (under damped) but after going up and down many times that has mostly faded away.
When going up and down its no longer a smooth movement it takes it in several discrete steps (although much faster than before i had suspension issues).
I have tried depressurising and pressursing the hydraulic system several times which has helped out the suspension at the expense of the brake pedal.
The brakes still work and the car comes to an abrupt enough halt but the pedal itself rests near to the floor, i'm suspecting therefore the brakes need bleeding to get the pedal back. (or is there a trick to pressurising the system that the haynes has neglected to mention).
Now here comes the main point for this thread, where is the bleed nipple located!
On the haynes manual it shows it to be roughly in the middle of the caliper facing the drive shaft.
Either they are showing a different model of brakes or i'm being really dense as it is not there!
Car is a 95N xantia 1.9 turbo d lx (non hydractive)
any help / suggestions would be most appreciated as well as links to appropriate threads (i've hunted for over an hour!)
