I have a problem with the front electric windows and sunroof of my '92 ZX Aura. They either work or they don't.
I've checked the fuses and cleaned the earth wires, yet problem still remains. Are there any well-known common faults which I should be looking for?
ZX electric windows and sunroof
Dave Burns
- x 3
I'm not aware of any common faults with the windows or roof, but I have a ZX TD and get this, sometimes the windows and sunroof will work without the ignition being switched on, only Citroen could make them like this, masters of schoolboy electrics.
Check if you have voltage up to the switches and at the fuses.
Dave
Dave
dave-b
jeremy
- x 3
must try that on ours! Slow passenger window may be helped by a good application of silicon spray to seal at bottom of window and the guide channels. Bit messy and not recommended if you plan spraying it tomorrow (silicon will make the paint look like hammerite) but it will clean off quite easily and beats dismantling it.
jeremy
jeremy
Dave Burns
- x 3
