Wind Back Front Brake Pistons
windysurferuk
Unread post by windysurferuk »
Hi
I'm in the middle of changing the front brake padson my 2.1 Xantia
I am struggling to get the pistions to wind back into the calipers
I have got one to got back in far enough to fit the new pads but it took about an hour.
The other side doesn't seem to be going back in not matter how much I
wind it. I've been at it for a hour and a half!!
Am I doing something wrong.I'm turning them clock wise.
Is there an easy way of winding then back in.I'm currently using a piece of square bar.
Cheers
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
When I had a 2.1 I found it easier to wind with a bar, but also use another bar to lever and put pressure on the turning bar.
AndersDK
Unread post by AndersDK »
As John writes you must press on the piston while turning it - or it will not "grip".
Not a laughing fun job :?
Anders (DK) - '90 BX16Image
macaroni
Unread post by macaroni »
It is a horrible job, but I found that you don't have to push it in whilst turning. Yo can just give it a few turns, push it in a bit, few more turns, another push etc, etc. It is much easier than turning whilst pushing.
f00lzz
Unread post by f00lzz »
Each time I do that job I promise to make up a better tool to use for next time....
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
