Hi All,
My Citroen constantly has this motor/pump noise whilst the engine is running, kinda getting on my nerves now. However, if you just turn the ignition on, you can here it for a few seconds and then it just goes away like a fuel pump priming. But soon as I start it, the noise comes on again and is there constantly.
Any suggestions?
Also does anybody know how to disable the annoying woman employed by traffic master?
Regards
Xantia 2.0 HDI Constant pump/motor noise like a humming!
icedillon
BonceChops
deian
pwatson
icedillon
icedillon
- x 694
It could be that evil little fan behind the dashboard for the temperature sensor, as suggested already. Mine makes an annoying buzzing noise as soon as I turn on the key.
I highly doubt it's the fuel pump as I was under the impression they're inside the fuel tank on the Xantia's so you wouldn't be able to hear it at all unless it was REALLY noisy.
I presume you've tried listening from OUTSIDE of the car when someone else turns on the key for you ? (To confirm whether the noise really is from outside or whether its actually inside)
Edit: just checked and on my car at least (different engine) the fuel pump is at the back. It makes a soft whining noise for about 2 seconds after turning on the key and then stops.
Regards,
Regards,
- x 1476
I think this probably is the fuel pump and / or the filter housing - there was a post about it not so long ago. When the pump starts to go, it creates pulsation that seem to amplify in the filter housing, knackering that too (or maybe there's a damper in the housing that gets knackered). My guess is if you take the cover off the engine and listen carefully the noise will be coming from the filter.
mezuk04
icedillon
- x 1476
icedillon
- x 1476
The pump is at the rear, the filter at the front. Vibrations from the pump cause the filter to make the noise. Problems with the filter can amplify the noise.
See
http://www.frenchcarforum.co.uk/forum/v ... hp?t=18318
and
http://www.frenchcarforum.co.uk/forum/v ... hp?t=18231
See
and
