xantia clutch change advice
basil
Unread post by basil »
Xantia 19td 95n 139000 mls.
The clutch has been slipping for a while but tonight it gave up completly :cry:
I got towed home by the power of a 800 cc matiz :shock:
My question is how difficult is it to do a clutch change with jacks/ramps (in the cold :cry: )?
I have tried searching for a" how to do" but no success,keep getting sidetracked by other posts.
Last year I did the head gasket over three weekends (with help from various posts :wink: )So how would a clutch change compare ?
Garage quotes range from ?275 (a fast fit place) to ?400+at local garage,but now I have the problem of getting the Xan to the garage.
________
Lamborghini V12 Specifications
dnsey
x 19
Unread post by dnsey »
You can't do it with just ramps. You'll need axle stands as a minimum, and a good jack to get the car well off the deck and to manoevre the engine and gearbox (unless you have a hoist).
Depends how much similar work you've done before - not too bad, but I wouldn't recommend it as a first 'major' job.
x 94
Unread post by citronut »
you will need both front wheels off the ground as you need to drop both of the driveshafts out,so axle stands are required,also if its a pull clutch you will need to remove the clutch lever from the fork spindle to allow the fork to rotate out and back into the thrust bearing
regards malcolm
AndersDK
Unread post by AndersDK »
have a peep here :
http://www.frenchcarforum.co.uk/forum/v ... hp?t=18353
The "spanner rating" (difficulty) of a clutch job pretty much compares to the HG job you've already tried.
The quotes you've got on the job are not too bad considered its a major job.
Anders (DK) - '90 BX16Image
x 1479
Basil,
You have mail :lol:
