Presumably the parts are dealer only, and dealer fit only, as it probably needs to go on the computer to code the new one in?
Or is there a bodge it and scarper fix?
it only needs a dealer computer if the car has ESP as the steering wheel angle sensor will need calibrated.on models without ESP its a straightforward swap.RichardW wrote: Presumably the parts are dealer only, and dealer fit only, as it probably needs to go on the computer to code the new one in?
Good!it only needs a dealer computer if the car has ESP as the steering wheel angle sensor will need calibrated.on models without ESP its a straightforward swap
Better!Your looking at 30 mins labour at a main dealer to change one, You should get away with a bill for less then £200 on most of them.
Even better - it was reg in Aug 02, so under 4 years old, and the unit was done about 2 years ago first time.Also from the cars date of first registration the COMM 2000 unit has a 4 year warranty.
Hi Clogzz & thanks.Clogzz wrote:ACTIVE8, your previous avatar was lovely !
