Hi guys, homefully someone can help me out here before i spend too much cash!
My 306 isnt right, the symptoms are as follows.
1. Juddery when pulling off, this only happens in 1st gear, and is gone once the clutch is fully up. Odd, if you pull off in 2nd, it doesnt do it.
I dont think its the clutch, becouse if i pull off at over 2000rpm, no judder.
2. I left the car for 5 days, and then it didnt start very well. I normally drive the car every day so i dont notice, but due to illness it was left standing. It was mis-firing and spluttering, untill i took it around the block, then all was well again.
The car doesnt pull like it should, especially at low RPM's. It feels as if some turbo kicks in (i wish!) at 2500 rpm ish, kinda ties in with the pulling off thing.
I had the car code-read by a Diag2000 machine before, due to an idle fault and had the idle controller replaced, thats all OK now.
Im 99% sure the car still has its original coil pack on (thats the bit that connects to the spark plugs, yes?)
Plugs, etc have been changed recently and this made no difference. Oddly, the car seems to judder less when she is cold (maybe related to the sam higher RPM thing whilst the choke is on).
Sorrry this is so long winded, i wanted to post as much info as possible!
Thanks again guys (and gals!)
Kev
306 Coil pack failure.
Linchpin
Paul Mi16
Linchpin
Paul Mi16
Linchpin
Paul Mi16
Linchpin
