Clutch Change 1.9TD
zzf00l
Unread post by zzf00l »
I believe that the 'Citroen Bible' quotes 8 hours to do the clutch on a 1.9td.
Anyway, I'll find out this weekend,
Sutton Coldfield, West Mids
Xantia V6 Exclusive (2000
Xantia 1.9TD SX (2000)
Previously owned
Xantia V6 Exclusive (97)
XM V6 Exclusive (95)
AX 1.4
x 1443
zzf001 you have mail 8)
zzf00l
OK just a quick update....everything had been going fine .... clutch out (centre had collapsed) new clutch in (Valeo from GSF) gearbox on lift.... lift breaks down.... get new part for lift on Monday (hopefully) work commences as soon as. :D Oh! it took me the first 2 hours of the job to split the bottom ball joint :( then it's been OK
Previously owned
AX 1.4
AndersDK
Unread post by AndersDK »
2 hours on the bottom balljoint :roll:
Do you know why I loosen the hub clamp and lift up the strut instead :wink:
Anders (DK) - '90 BX16Image
zzf00l
I see that now....but you live and learn :)
Previously owned
AX 1.4
zzf00l
All done! What a relief... pleased I did it myself but hope I don't have another one to do fo a long time. Just one query, I feel that their is a little to much play at the top of the clutch pedalis their some way of removing it or should I have used a new cable?
Thanks for the help and support you guys.
Previously owned
AX 1.4
