Hydraulic fluid frothing
robzondrumz
Hi,
I wonder if anyone can help me with my xantia. Brakes started to grab and bind and when I looked in the reservoir the fluid was bubbling away like mad. I then tried to bleed the brakes and the fluid came out like guinness!! System is getting loads of air in it somewhere but I have run out of ideas on the problem. Can anyone help??
thanks
Rob
thanks
Rob
mezuk04
jeremy
- x 3
You have an air leak on the inlet side of the pump. With luck its the hose and tightening or if there is enough pipe, cutting off the ends so that fresh pipe is used may solve the problem. It is possible that the hose itself if porous - in which case for diagnostic purposes it can be replaced with a clean section of garden hose.
Some xantias have a pump on which the inlet pipe arrangement can crack and fall off. Careful inspection may show up a crack.
jeremy
robzondrumz
jeremy
- x 3
The pump inlet hose is generally black rubber (its not in fact rubber) and looks like a heater hose. (Don't substitute heater hose - its probably soluble in LHM)
To expel gas try Citroebics - raising and lowering the car fully many times - this causes the LHm to circulate and carry the gas out with it. You may get away without bleeding the limbs going to the brakes if you are lucky. You will probably have to prime the pump - open the pressure relief screw on the regulator - 1/2 or so - NO MORE otherwise a ball bearing will fall out - start the engine, fill the reservoir end of the pump supply pipe with LHM and fit it to the reservoir quickly and tighten the clip. Let the engine idle for a couple of minutes and then close the pressure relief screw. - The car should now rise.
jeremy
- x 1240
robzondrumz
robzondrumz
- x 695
Presumably both ends are clamped nice and tight with jubile clips ?
Did you prime the new pipe by pouring LHM into both ends before attaching them ?
When you first replace the inlet pipe you need to idle the engine for several minutes with the pressure regulator bleed screw open (half a turn) so that there is no load on the pump and all the air can return to the tank.
When I replaced the LHM in the tank on mine (and in the process got air into the pump circuit) I had to idle it for a full 5 minutes with the bleed screw open before it stopped frothing.
Once it stops frothing you can then close the bleed screw and do Citreobics.
If its still frothing after 5 minutes idling with the bleed screw open you must still have a leak.
If you're sure about your hose repair that could possibly indicate the pump itself leaking air
Regards,
Regards,
robzondrumz
robzondrumz
robzondrumz
Clogzz
- x 40
robzondrumz
