XM 2.5 Gearbox Oil Level Plug
rg
Unread post by rg »
Folks,
Haynes and Russek seem to address the BE3 only.
Is the plug on the front side of the casting, up by the regulator?
I've found one there with a copper washer, taken it out, but it is around 2
inches long, and threaded into something steel, rather than the alloy
casing.
I recall a horror story of a Simca gearbox losing some kind of vital
spring inside due to mistaken removal of what appeared to be a drain plug.
rg
x 1238
Unread post by Peter.N. »
From Noz's file it seems to be in more or less the same place as the 2.1
Squareroot
Unread post by Squareroot »
The level plug on the MG 5 T gearbox on my '95 2.5 XM is on the inner end of the box behind the offside (RHD) driveshaft oil seal. I hope this helps and apologies for the late reply.
jeremy
Unread post by jeremy »
If it would help to have a look at the partsbook it can be found:
http://www.tramontana.co.hu/citroen/
Follow the link just below the red line - both series 1XM and series 2 are there. Big files which will download on Mozilla Firefox but not IE if you are on dialup. (1650 odd pages each)
jeremy
NiSk
Unread post by NiSk »
Or you can look at just the section you need at:
http://pepon1.free.fr/
Click on XM and the catalogue de pieces
The catalogue itself is in English once you get there.
//NiSk
rg
Unread post by rg »
Thanks, all.
Photos are here:-
of the plug locations.
rg
