xantia front and rear lights suddenly stopped working
al_sapper
Unread post by al_sapper »
xantia front and rear lights suddenly stopped working. I have checked all fuses and are ok. power coming into the switch arm. Indicators work ok.
Any sugestions please.
x 1238
Unread post by Peter.N. »
Is there more than one an auxilluary supply lead connected to the battery? if so check for good connection.
al_sapper
Yes checked battery connections. Still no joy
zxTd
Unread post by zxTd »
age of car would be nice, put as much data on the car as possible it makes a diagnosis much easier :wink:
al_sapper
The xantia is 1.9 td 1999. V reg. 5 door
AndersDK
Unread post by AndersDK »
You know there is power on the switch - and the fuses are ok.
But have you checked there is power on the fuses when lights switched on ?
Could hardly be wear or corrosion on a '99. Believe a connector has parted its place somewhere.
Anders (DK) - '90 BX16Image
al_sapper
Yes have checked this and the fuses seem to be ok with lights on and off.
Could it be a the relay? Where is the relay for the front and rear lights situated? xantia 1999 td.
Thanks for any help.
AndersDK
al_sapper wrote:Yes have checked this and the fuses seem to be ok with lights on and off.
What you mean by "fuses ok with lights on and off" ??
What I meant was you to check with a testlamp that you really have a beefy and good +12V on the fuses when lights are switched on. This means you put one side of the test lamp to each fuse in turn - and the other side of the test lamp to ground (chassis). The testlamp should of course light up.
Its very important to know if you have a +12V on the fuses - as this is a milestone in further fault tracing.
No relays are involved if there are fuses for each lamp function. Unless of course previous owners have messed around ...
Clogzz
x 40
Unread post by Clogzz »
This fault rings a bell.
The wiring loom that passes along the bottom of the radiator is a favourite for very strange electrical faults that affect the lights.
See story here:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=16816 2 pages
2002 C5 2.0i AL4 239,000 km 76372389
