405 Wonky fog lamp switch
demag
x 102
Unread post by demag »
I've noticed over the last month that the warning led on the rear fog lamp switch started glowing.
If I pressed it in and out a few times it would go out.
Now it is on permanent whenever the lights are on but the rear fogs are out.
Checking it yesterday with the sidelights on. If I pressed the rear fog switch the dip beam came on!
Obviously a problem. Any ideas?
Thanks,
Dave.
Dave
pugxpert
Unread post by pugxpert »
bad earth on rear lights check in tailgate i think there are some earth blocks
EP6T petrol turbo nice engine in the 207 GT and the new mini....
PowerLee
Unread post by PowerLee »
Its the earth at each rear plug on the rear lights, Best way to fix this is add another earth wire & solder it with a high temperature iron to the main metal body part of the lamp holders.
Once you get the extra wire on attach it to the main earth wire & job done.
