406 D9 2.0 A/T gasoline
Hi, how ru doing.
1. My VIN is VF3**************[VIN obfuscated, can be read by forum staff], which type is my engine? XU10 or EW10?
2. My A/T was in problem of pressure regulation, so I changed two new
solenoid valves(main pressure regulation valve & converter pressure
valve), part code is 2574.16, but old valve code is 2574.10. I've heard
that my ECU is not compatible with new valves(2574.16), I have to update ECU software. (not upgrade ECU yet). So I would like to know:
If not upgrade, what would happen?
My ECU built on 6(June)2001, if it would identify and control new valves?
Normal pressure should be 2.2-2.8bar, after fitting new valves, it is 2.8-
3.05bar, is it normal or any damage for transmission?
thanks
406 AL4 alutomatic gear fault
pugxpert
Hi ,firstly your engine is an xu10 the (ew has engine code rfn). not to sure what will happen if you run gearbox on old software with new valves but i know that the internals of the valves have changed from metal to plastic to stop particles sticking inside the valves,the new type valves are borg warner type,if you go into gearbox ecu there is a screen which shows if ecu is borg warner compatible for solenoid valves. also when you reset oil level @60 degrees once this is done another half litre of oil should be added,later gearboxes have two rings on oil level tube this indicates that it already allows for the extra 0.5 ltr. when downloading gearbox ecu disconnect engine ecu ,sometimes has a problem causing download to crash!! hope of some use.
EP6T petrol turbo nice engine in the 207 GT and the new mini....
jonasy
- x 1055
Borg warner is just the manufacturer of the electrovalves.
The injection ECU should always be updated at the same time as updating the autobox ECU.
When you check the oil level you add the 0.5L first ,run the engine up to 60 degrees C,select all the gears then back to park,remove the inner drain plug (with the engine still running),if it flows then drips the level is ok,if it just drips you need to repeat the procedure until you get it to flow then drip.
pugxpert
jonasy
pugxpert
add your 3 litres then another half litre run up to 60 degrees and loosen 19mm in centre on drain/level bung if oil does not come out add another 1/2 litre and recheck at 60 degrees if oil flows out let it flow untill no more comes out level is now set. somewhere i have read in a tech letter about adding another half liter on top once level is set but cant find it at the moment.
jonasy
dear friend, i mean i wanna try to change out all old oil, but every time, I can only drain out 3L. then i have to add 3L, drain 3L, then add again 3L, then drain 3............... do you think necessary?pugxpert wrote:add your 3 litres then another half litre run up to 60 degrees and loosen 19mm in centre on drain/level bung if oil does not come out add another 1/2 litre and recheck at 60 degrees if oil flows out let it flow untill no more comes out level is now set. somewhere i have read in a tech letter about adding another half liter on top once level is set but cant find it at the moment.
besides, can i update ecu in citroen's garage? their diagnostic computer can identify my gearbox and engine ecu.
- x 1055
you will never get all the oil out,the box holds around 5 litres but you cant fully drain it as the torque convertor still holds around 2 litres.
Any Citroen garage with a Lexia or Proxia machine should be able to update the software as the ECU's are the same,just enter the car in as a C5.
I dont think that adding another half litre after setting the level should be done as the level on these boxes is critical,the tolerance is 0.1 litres
pugxpert
