Amber Bulbs not Lenses
bbrucez
Took the Xsara for MOT yesterday feeling quietly confident despite presenting the £10 off voucher before the test.
Was rather miffed when I was told all 4 of the indicators were too white but he was probably correct. To avoid failure & retest I let them change the bulbs. Sure enouigh the amber coating had flaked quite a bit off on all of them. What a design flaw - why not stick with amber lenses?
Miffed turned to shocked when he charged me £12 for the bulbs (they're a lot more expensive, guv) & £10 to fit them and then added VAT so my final bill despite discount voucher was £60.02!!
He said he fits hundreds for people like me so buys the bulbs in bulk. Not a bad little earner - makes a change from changing good wiper blades for dubious quality new ones.
Take my advice & stock up when you see them cheap before your MOT not after like I did (99p a pair on Ebay). Even Halfrauds are cheaper than I paid. I bet Trago Mills (in Devon & Cornwall only) are cheapest of all because they are on all other bulbs - anyone know?
Cheers,
Bruce
2001Y C5 2.2HDI
1972K Volvo 1800E
2003 53 Smart Passion
1998S Nissan Skyline GTR VSpec
Bruce
2001Y C5 2.2HDI
1972K Volvo 1800E
JohnD
- x 72
rory_perrett
Not uncommon I'm afraid the coat just drops off, but in contrast at the place I get my cars MOT'd he charges £1 a bulb inc VAT and hands them to you saying, "just fit these lad while I write out the certificate". Probably won't happen now they've gone computerised and the certificate is printed out.
- x 94
dnsey
- x 19
user_3150
- New User
j_roc
Bloody hell!!!! A tenner to fit some bulb's, how much do they now charge for a clutch to be fitted???
. Makes me glad that im a mechanic and can do it myself. As I aint had to M.O.T one of my cars since the new test came into force (as far as im still aware of) if your car is still on the premises you should have ASKED for the bulbs for you to fit them there and then - as they need your permission to do any work to the car, either if it fails or not. - Alex
- x 1238
_kid_
Mine failed on exactly the same thing this year, this was a council run mot station which is neutral. I thought he was having a laugh, but sure enough when i took bulb out the external amber coating was flaking off. Went to Halfrauds £4 for two bulbsPeter.N. wrote:I'm very sorry to tell you this, but you can get the offset pin amber bulbs from GFS for about 69p!
Funnily enough the old bulbs which failed the mot had were Philips, so much for brand quality
currently no citroens
1.4 2000 forte now gone too
xantia 1.8i 16v dimension 1996P now gone,
bbrucez
As their labour rates are the cheapest in my area (£40 p/h) I s'pose he did take 15 mins to fit them which seems about right. I just felt conned but relieved that it passed.
Ironically, the bulbs were original fitting so they had lasted well.
If only they still wrapped Lucozade bottles in amber cellophane!!.
Cheers,
Bruce
2001Y C5 2.2HDI
1972K Volvo 1800E
Bruce
2001Y C5 2.2HDI
1972K Volvo 1800E
Linegeist
wilkobob
Gnerk
I don't own a Xantia, so you can tell me to shut up. However, would one solution be to colour the indicator lenses in amber (as per other cars)? Then presumably doesn't matter if the amber colour comes off the bulbs...
________________________
Renault Laguna II 2.2 dCi 2002 (bought June 2012)
Nissan Micra 1.1 96P (Mrs Gnerk)
Citroen ZX 1.9D Avantage 95N (untidy but runs wells, FOR SALE JUNE 2012)
martyhopkirk
fastandfurryous
- x 4
Or...
Smash open the front indicators on a 1993-1998 fraud 'scort. They use clear bulbs, and clear lenses, but have an amber plastic lens that the lamp sits inside. I'm sure a bodge could be put together to use these on a car that needs them. Much cheaper than £25 for a couple of lamps!
This is not a signature.
