Hi all
Can someone give me some advice. I've just bought an XM and the steering meets resistance about every third of a turn in both directions. Thought it was the columm and uj out of alignment, but now not so sure.
Any thoughts please?
Steering resistence on XM
Silly point - I suppose the hydraulic pump drive belt is sound and very tight?
Pinion valve tends to wear on one side first - so one side affected. FDV - well thats a different matter and should give priority to the steering. From my own experience and reading between the lines here when it fails generally the rest of the hydraulics suffer and the steering is OK. The remaining bit is pump which could be weak.
Can't you eliminate your mechanical problem by jacking both front wheels clear of the ground and then turning the steering with the engine turned off? It should be smooth and free then - if not the suspect mechanical.
Jeremy
Jeremy
Thanks Guys
My local Cit dealer first suggested hydraflus, but the only inconsistency is that brakes, hydraulics etc are all A1 - it goes up, down and stops on a dime so pump seems ok. I personally thought it was one of the UJs out of sync/bottom of steering column bent, but a friend in the AA said he thought it was a worn pinion/rack (teeth broken/missing etc), which is why I wondered if anyone here had had the same probkem.
I will jack the car up this weekend and see if it does it with the wheels in the air.
Thanks all in the meantime... given me a few things to check.
The Series 1 XM's had a HP pump with a single outlet, 9 piston rotory construction and a Flow Divider Valve to distribute high pressure oil to the steering and all other circuits. This valve can be a right pain in the neck, and running hydraflush through it is one way of dislodging any crap floating about in the system. The steering system has its own overflow valve for controlling the pressure to the steering and returning used/overflow oil to the reservoir. It uses by far the majority of HP oil from the pump.
Series 2 XM's have a so called "Xantia" pump with two outlets, six pistons supply the steering alone, the remaining two supply the rest of the cars hydraulic systems (brakes, suspension). This gives you an idea about how demanding the steering servo is!
//NiSk
//NiSk
You can see the differences here : http://www.tramontana.co.hu/citroen/mod ... odels.html
The later 2+6 hydraulic pump would clearly have 2 steelpipes connected (and the rubber feed hose).
Early (9 piston) pumps only have a single steel pipe (and the rubber feed hose) connected.
When it went to Citroen for advice about the steering, the mechanic took one look under the bonnet and said "carburettor, eh? So you're used to it not wanting to start when hot?" which is exactly what I got. It certainly doesn't like doing anything other than idling until it gets hot, similar to how I remember old carb jobbies.
