BP Radio
BrianM
BP Radio
Unread post by BrianM »
Anyone any idea how long it takes for the radio to come back to 0000 to allow the code to be entered ?. It is showing ---- and has been like this for 18 hours at this stage. The last time it came back to 0000 it only let me put in the code once ( which was still wrong [V])
Its a Blaupunkt PH1C in a 97 Xantia
zorgman
Unread post by zorgman »
if i remeber correct the radio has to be powered up all the time to do this
BrianM
I have drove the car for over an hour with the radio on but it still hasnt come back to the 0000. I'll leave it on longer and see what happens.
meexi
Unread post by meexi »
Hi Brian,
I believe that you have to press the band button and that should activate the code screen.
Meexi
BrianM
Left it switched on for 1.5 hours, went out and entered the code I got from http://radiocode.proboards6.com/. All is ok again [:D]
Brian
