Height corr. spring and arm
bernie
Unread post by bernie »
Can some kind soul help me please?
The bent arm from the Xantia rear h/c has a slot, a square hole and a cut out on the end.
Which one takes the pin from the lever and which takes the two ends of the return spring?
As you can probably gathered I took the h/c off to overhaul and can not work out to get it back.
bernie
Or can anyone point to a picture on the net?
harryb.48
Unread post by harryb.48 »
Bernie ,try this previous topic which has an expanded pic of h/c
http://www.andyspares.com/discussionfor ... IC_ID=7262
Regards
bernie
Thanks Harry
bernie
BTW Harry, where did the diagrams come from?
Nothing like that in Haynes[}:)]
