Hi everyone this is my first post and cry for help
My 306 handbrake has always been poor requiring a real good pull to hold the car on a slope and i leave it in gear just in case. Last year it passed the MOT ok. Its just failed the MOT due to low handbrake efficiency. The tester said it was due to worn discs and pads. I have changed these (the old ones looked ok to me) and the result is just as bad if not worse. I have adjusted the cable with no improvement. The foot brake works ok. My next move will be to change the cables incase one is stretching as there does seem a lot of movement on the HBlever
Has anyone any advice to offer before I shell out more cash?
306 HDi handbrake
Dave Burns
- x 3
Check that the levers on the calipers return fully to their stops, unhook the cables to make sure, if they are part way through their travel due to incorrect cable adjustment there will be a reduced amount of leverage.
While the cables are unhooked push and pull on the inner cable, it should move freely inside its outer sheath, if they do they are ok.
Dave
Dave
IROBOT
IROBOT
Dave Burns
- x 3
IROBOT
