xantia reversing lights
crooser
fuses and bulbs are ok on my 97 xantia saloon but no reversing lights.can anyone suggest the next step if this is a known problem.
beezer
crooser
beezer
crooser
beezer
crooser
beezer,it was the reversing light switch.on a xantia like mine[97 manual]the switch is under the clutch operating lever which in turn is under the wiring loom,hydraulic pipes and a big plastic moulding that carries wiring and pipes which in turn is under part of the battery case and air filter.citroen-another challenging job done,you will not beat me.
beezer
uhn113x
- x 3
