Wheels
andy.blurton
Wheels
Unread post by andy.blurton »
what other wheels fit the citroen xsara as we have recently lost one in a blow out incident and want to replace it quickly and at the lowest cost? Can anyone help!!! They are 195/55 tyres on a steel rim its a 1.4 petrol saloon.
jeremy
Unread post by jeremy »
Tell us a bit more - are they alloys or steel, what is the tyre size? As a matter of interest are they 14 inch black painted steel with holes round the disc? If so they are probably the same as ZX, some BX . . (most BX have solid centres - some GTi's may have holes which may be needed for brake ventilation)
If they are steel it is possible that your spare is in fact on the same rimwith a smaller tyre. Our ZX looks like this is the case. You may find some part numbers on the rim itself (around the bolt holes?) which may asssist confirmation.
jeremy
andy.blurton
They are steel 195/55 is the tyre size. not sure on the part number does this help?
weety
Unread post by weety »
i managed to get a xantia wheel on the back of a xsara once-need to check it fits on the front as well though
