disc corrosion
discovered
disc corrosion
Unread post by discovered »
Having recently had my 52 reg citroen saxo 1.1 in for its 2 year service I was amazed to be told that the front brake discs were severely corroded and was quoted £197 + vat for them to be replaced ...not covered by the warranty.
I was told this was due to my low mileage(8000 the first year and 9000 the second!!!)
Has anybody else had experience of this or does anybody have any advice?
madasafish
Unread post by madasafish »
Wife'sPeugeot 106 neede new discs after 15k miles: she drives and brakes gently. Since I changed them myself with parts from H######s for abouit £55 I dsrive it once a week and give it an Italian tuneup. No problems now...
Brake hard at least once a week. If you wash the car and let it dry normally the discs will corrode. If you use wheelcleaners (eg Wonder Wheels) they are acidic and make things worse.
Always try to dry the disks after washing the car: a few stops in your drive from 5mph will help..
beezer
Unread post by beezer »
My advice is buy the discs at GSF for £12.95 each and do it yourself.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
I would have wanted a second opinion. A 1998 Saxo is included in the fleet of four family cars that I look after. Its yearly mileage is much less than yours, yet its discs and pads are in first class condition. Maybe the workshop were looking for work!
