306 sunroof
aystevie
306 sunroof
my sunroof leaks, is there anyway to adjust, or do i need to replace parts?
PowerLee
PowerLee
Hi
Open the sunroof, You should see in the channel around the roof 4 x small holes.
These are the drain holes, best way to test them is fill a cup or jug with water, fill the channel up carefully to cover the holes & then see if you get 4 nice little streams of water appearing.
Im not sure where the drains lead to on the 306, You should get 4 x small puddles of water around the wheels.
Dont poke any wire down the drain holes to unblock them because the tubes damage easily, use an airline.
