LHM Overfill
mattpc
LHM Overfill
Hi, my 95 Xantia TD SX was a bit low on LHM so I topped it up as instructed by Haynes. Now when I check the fluid level out with the car on maximum height setting there appears to be too much fluid. Is this going to damage the system or will I be okay? It's about two weeks since I added fluid in which time I've probably done about 1000 miles.
nick
The worst that will happen is that the fluid will spill over the top of the reservoir and make a puddle under the car.
Personally I have always checked the fluid level on my Citroens by putting the suspension on the <i>minimum </i>height setting, then filling the reservoir til its almost brimming full & completely ignoring the level indicator altogether! With practice you can judge how much to put in without it ever spilling over.
mattpc
