I recently had to borrow a Torx T55 bit to replace my front discs on my Xantia, but this source is unlikely to be ther for uch longer.
Is the T55 size used much elsewhere on the vehicle?
I had tried to buy a T55 bit but found that they are very rare, my existing Torx set goes from T50 to T60.
Do the sets sold by GSF part numbers 98730, 98731, or 98732 contain a T55 bit (Bit as opposed to socket) Or can anyone recommend a not too expensive solution.
TORX T55 bit?
- x 1431
davek-uk
beezer
I got mine from a local tool shop in Glasgow (not local to me now as I've moved) but you can get a decent Britool one online from Toolbank
http://www.toolbank.com/product.cfm?CFI ... 65F96s8gyd
JohnD
- x 72
JohnD
- x 72
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rpaco</i>
The set I have comes from www.screwfix.com It's made up of T20,25,30,40,45,50,55 and comes as two sets in 30mm and 75mm lengths with a 1/2 inch drive adapter. And all for £7.99. Only trouble is that if your order is less than £45 you get clobbered with £5.95 p&p.
xantiav6
- x 3
