Today I've changed my fuel filter and used the Haynes manual to help me. When I got to the bit where I need to bleed the fuel system all was well until I needed to "loosen the bleed screw located in the injection pump inlet pipe union bolt" this I couldn't find.
I pumped the fuel without doing this and the car works fine. Should I go back and do this and if so where is the bleed screw?
Thanks.
Bleeding Xantia fuel system
Kowalski
JohnD
- x 72
wrinklet1
