Just wondering if it's normal to lose approx 4mpg when the weather turns cold? This is my first diesel (Volcane TD) & have had it since June & always averaged around 50mpg but now it's dropped to around 46mpg suddenly without a change in driving style. I have done a full service using Total Quarts Semi-Syn & all filters changed which improved it from 44 to 46 but where has the rest gone suddenly? Is it purely down to the cold(er) weather of late?
Cheers,
Ian
PS. Also considering putting some injector cleaner through it but it's not smoking more than normal so not sure if this is needed?
TD MPG in cold weather?
drpau
Kowalski
I keep pretty accurate records of my cars fuel consumption and have graphed the results. I can't see any seasonal trend on the graph over 3 years of TD Xantia driving (50k miles). My driving tends to be long journeys (35 miles to work) at dual carriageway speed.
Have you checked your tyre pressures?
How smooth running / smoky is your engine?
Does it use oil?
Does it use water?
Do you have a binding brake?
Do you have aircon?
Have you recently installed a roofrack been towing a trailer?
Has your route changed?
There are lots of things that can alter your fuel consumption, just some of them are listed above.
Does it use oil?
Does it use water?
Do you have aircon?
madasafish
Kowalski
In theory...
Engine efficiency should be better with colder air.
Aerodynamic drag should be less with warmer air.
So all in all, not a lot of difference winter to summer.
A modern multigrade engine oils viscosity shouldn't change too much since it has all of those viscosity modifying additives in it.
AndersDK
Ian -
I suspect you may have a problem with engine temp.
Try read this for any clues : Diesel coldstart device
davek-uk
Kowalski
nick
IanD
Kowalski
IanD
