http://i12.ebayimg.com/01/i/02/a8/1e/a1_1.JPG
Ive got a 98 saxo (single button plip with no key ) I got 1 plip with the car but the rubber button is badly worn and almost unusable (works about 1% of the time but does work if pressed enough different ways!) I've looked on ebay and I can see exactly the same single button plips and they seem to be goin for around £20. What im wondering is - will I be able to buy just the plip case from citroen? and if so does anyone know the part number for this? and how much this costs?
I'm also goin to buy a plip from ebay so I have 2 working plips. Does the method I have seen on this site for reprogramming the xantia plip work with the single button saxo plip? or will I have to pay the £30 odd to get citroen to do it.
Also can Citroen reprogram a plip from a 106 to a saxo as the single button plip case is exactly the same.
all info appreciated!
cheers
kenny
saxo remote plip needs replacing
- x 1044
i dont think the IR plips on saxos can be coded to other cars even by citroen,when you order a plip they come pre coded,it is ordered by the number (5 digits i think) on the white sticker on the back of the plip circut board & also on the recever.alternatively you can buy a complete pilp & recever set although it is quite expensive.
fiff
- x 1044
