Date stamped sphere's??
I have just looked at my 2 green front speheres above the front struts and noticed they have what looks like a date stamp (04/01). I have just bought the car, is this likely to be a date stamp, and if so can I presume therefore that the front 2 sphere's have been changed since April 2001?
If this is the case would they need changing again now? I don't know how mwnay miles the car has done in the last 3 1/2 years.
My haudraulic fluid looks clear and green.
You dont change spheres based on a time or mileage scheme.
You go by the feeling of the suspension. If it is hard - does not resemble the "Citroen feeling" - then change the spheres.
Testing is easy :
Have engine idle, height control lever in normal, handbrakes on.
Now press down each corner of car. It should feel nice & sofr to press down - like any other car.
Any corner that seems NOT to give under your pressure - will have a flat sphere.
Then you go change BOTH spheres on same axle.
The hydraulic system test goes as follows :
Have engine idle, height contol lever to MINIMUM height, handbrakes on.
Now the pressure regulator (pump) should emit those wellknown Citroen heart beats (ticks) with an interval of at least 30seconds. The longer the better.
Less than 30 seconds down to some 10-20 seconds, means the accumulator sphere (on engine block) must be replaced.
Read more basics here :
Citaerobics
LHM fluid service
Testing is easy :
Citaerobics
LHM fluid service
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
The new spheres I've bought generally have bought that have had dates on them tended to be recently manufactured, maybe I've been lucky.
Spheres generally last 3 years / 60,000 miles as a maximum. I've not had spheres that lasted longer than either of these milestones, I've had remanufacured spheres that did last anywhere near as long as this.
O.K. you sceptics! HOW long can a Citroën sphere last??
I was pretty sure that I still had the original spheres on my '93 XM TD12 - well, I've just been out and read off the date codes:
R.H. Front: code 96087008, date 3 - 148, L.H. Front: same code, date: 3 - 125, Accumulator (which was swopped last year for an sphere with an in-situ refilling valve fitted) code "Stamped" U printed 5451376 date 1 - 252 !!!
And they work perfectly (all are fitted with refill-in-situ valves).
Bad news for sphere salesmen I'm afraid.
//NiSk
//NiSk
Our '83 A reg BX still had all its original spheres and LHM until about 1997, only then did the ride quality begin to noticeably deteriorate and I changed them all & replaced the fluid. The car had covered about 40k by this stage, for a couple of years it only did about 50 miles per year according to the MOT certificates!
....I have wondered if spheres actually have a longer shelf-life when fitted to a seldom-used car like ours than they would if they were still in the box in a warehouse for example?
Even after several months of the car being parked up, the hydraulic circuits will probably retain a certain amount of positive pressure, which will act against the diaphragm in the spheres and help to prevent the nitrogen on the other side leaking through.
A sphere in storage will only have atmospheric pressure on one side of the diaphragm, so the nitrogen on the other side will be able to leak through more easily.
Just a theory......!
My rears were last done in 97, and are still comfy!! I did the fronts not long ago with Alko spheres which seem OK.
They should last a lot longer than they actually do-Hydragas spheres, although at a lower pressure, never go flat, and are indeed not even replaceable without changing the whole displacer unit and they will outlast the car they are fitted to, and are still usable after years of lying in the scrappie!! There are Allegro's and Princesse's running about which are getting on for 30 years old which have never even had the fluid changed.
Although similar construction - the Hydragas units are different from Citroen spheres.
The problem with Citroen spheres is the N-gas diffusing through the nitrile rubber membrane. It is not actually leaking - it's down to the molecylar basics.
It may certainly help having the spheres fitted on a pressurised system - as then the pressure difference over the membrane is nil - because of the equilibrum reached.
