Hi all,
I have just become a proud owner of a 205 diesel.
Its a 1995 model so has all the extras including power steering.
I have noticed though at low speed and when staionary the power steering is distinctly lumpy. It almost jerks its way round when you turn the wheels rather than being a nice smooth motion as I would expect.
i've heard that this is normal on the 205 diesel but I'm not convinced...
Has anybody else come across this or know what I should check???[?]
The rest of the car is great and I don't want this one little thing to spoil it....
Thanks!
205 diesel power steering at low speed
ianb
goatboy
kevin
I have a similar problem on my 306, the steering column has a UJ at the bottom of the shaft that sometimes siezes up after damp conditions. There are two types, a long and a short and two ways of correcting this problem, an expensice and a cheap way.
Expensive, replace complete joint
Cheap, apply liberal quantities of copper or lithium based grease every 3 - 4 month's
Good luck
Dr R V Swirl-Chamber
Good luck
goatboy
Dave Bamber
Is the drive belt on the pump tight enough?
If the pump is leaking or the cam seal is leaking, this can foul the belt and cause it to slip and make the steering feel strange.
I've had a seizing U/J on a manual 205 recently. A good soaking with oil free improved it, but it would be better to replace the joint in the long term.
goatboy
