When looking under my Xantia HDI estate i noticed the anti-sink sphere has the marking ACC on it. Could this be an accumulater sphere fitted by mistake. If so what effect will it have?
anti sink
Stempy
Richard Gallagher
Antisink spheres have a totally different connection compared with 'normal' spheres because the 'outer' body-thread is used only to 'mount' the sphere, the connection is actually made by way of a small metal pipe rather like a brake pipe which runs into the centre of the sphere.
Therefore its impossible to mix/match them.
Stempy
AndersDK
... and you would never ever see/feel ANY difference whatever antisink sphere is fitted - or not [8D]
- as this is only used for rear brakes accumulator - once the engine (and then hyd pump) is turned off - or stalls during drive.
- meaning only in extreme cases you would ever notice the missing rear brakes.
Nothing to do with the antisink feature itself, but rather a precaution added because of the antisink feature.
