Hi all,
Would just like to get other users views on what type of water to use for engine cooling.
My views for what it's worth are as follows:
1.Tap water-it's a lottery, depends where in the country you live, I understand that Scotland is the best !!!,to test see how quickly the kettle scales up, and how hard the scale is.
If it scales up in say a month, and the scale is hard, then don't use it, if on the other hand there is only a slight mist on the element and easily rubs off then this should be ok.
2. Rain water, should be ok if you reside in a non industrial area.
3. Defrosted water from fridge or freezer, should be ok.
4. Water collected from a de-humidifier, also should be ok.
5. best is to use demineralised water.
Cheers
COOLING WATER
JohnD
- x 72
Stuart McB
alan s
- RIP 2010
- x 6
I'd go #4 or #5 but if in doubt, take a sample to a pet shop who sell fish and ask to get it tested.
Over here, tap water = acid and rainwater from a tank = alkaline. Preferrably neutral is the best result as in the case of acidic and certain metal combinations can become quite active as regards electrolysis which in turn creates massive corrosion. Tap water may be OK if it stands up to the tests; calcification is only one aspect of it and not a very significant one I'm afraid.
Alan S
Alan S
portugeezer
tomsheppard
vanny
Stuart McB
Dave Burns
Don't fanny about just use tap water where ever you are and the proper citroen antigel antifreez, gordon bennet how much furring can eight or nine litres of water cause even in the hardest water area, don't forget what you see in your kettle is an accumulative deposit and doesn't just end up furred to buggery from the first few pints, I allways use tap water and have never had any problems.
Vanny use tap water, but let it stand to allow the ****e they put in to evaporate off, or heat it to drive it off faster, the area the water comes from that are used in beer making is on of its characteristics, the worst thing you can do is use bottled water, its been mucked about no end and even distilled water probably contains contaminants like dead skin cells from bottles and blow moulding machines being handled, just like the bottled spring waters[:0]
Dave
Dave
martyhopkirk
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by vanny</i>
Will i got shot for this post?
I think its been established which water to use in the car, but what about when making home brew?
Tap water from Freckleton mate - pure nectar when brewing me bitter!
PeterMann
If your car is a Xantia, then to use a high proportion of ethylene glycol in the coolant water is a VERY IMPORTANT investment.
I recently discovered that the heat stored in the engine can cause high pressures in the cooling system . . . high enough to upset the seals at the heater matrix. And the Heater matrix is one part of your Xantia you NEVER Ever want to see.
If mixing from a glycol concentrate, use a demineralized water because dissolved chlorine and minerals will make it harder for the buffering compounds to prevent CORROSION.
John F
Hi, have read all the archive material about what water to use and the concerns about venting the system correctly but I can't seem to find information where all the bleed valves and drain plugs are on a Xantia II though I do remember some one saying that there was a drain plug or similar on the rear side of the crank case; could someone please tell me where to look for the drains and bleed valves because if it means crawling under the car more than twice I am in real difficulty.
