Xantia Air con again!!
Post your Cit/Peu/Ren air conditioning queries or advice.
ghostrider
Unread post by ghostrider »
Ok so now the fans are fixed, dodgy contacts, I have a leak from the air con where the pipe from the compressor and the pipe from the dryer bottle are coupled to the condensor. So after all the effort of doing the fans I've still wound up dismantling the front end[xx(]!!. Good old Citroen, loads of ally pipe held in place by a nice bit of mild steel[|)] [|)], so yet again dissimilar metal corrosion has destroyed the ally pipe, fortunately the condensor where the pipes go in is ok, so I just need new pipes, down to the local cit dealer, yes we can get them to you sir ?139 oh yes and you'll probably need a new dryer bottle ?63 and a regas at around ?40 ( not from cit dealer) [xx(][xx(] So does anyone know where I could get these hoses made up for some sensible money
Thanks Pete
________
Extreme Q Vaporizer
john alexander
Unread post by john alexander »
try hydrasun or another hydraulic hose company
ghostrider
Thanks John, I'm typing it into my seach engine now will post results if I have any success
Pete
________
Honda Cbf250 Specifications
