Xantia II Aircon cabin temperature sensor
Post your Cit/Peu/Ren air conditioning queries or advice.
John F
Unread post by John F »
Hi, I've looked in the archives but cannot find the info I require, which is, does the aircon temperature sensor have a fan to circulate the air over it and how do I get to the fan/sensor in order to check/replace as necessary?
Stempy
Unread post by Stempy »
Yes it has a fan, but it's not easy to get at. If you listen by its intake slots you will hear it running. If you can hear it it's working so best left alone. All it needs is a blast of aerosol air duster down the slot periodically to blow the dust off the temp sensor.
